Geocritter's avatar
Geocritter
Need help with carburetor adjustment on my Onan generator
I’ve been working on The Behemoths generator lately. My rig has a 7kw Onan gasoline powered generator. When I first tinkered with it I learned that it needed a new circuit board, which I was able to purchase from a Dinosaur Electronics distributer. I also replaced the oil, oil filter, and spark plugs. However, it didn’t run long before the spark plugs fouled out. The fouled plugs and the exhaust odor pointed to carburetor problems and a possible bad valve (one of the two original plugs I’d replaced was heavily fouled). I serviced and thoroughly cleaned the filthy carburetor inside and out and also gave the engine a compression test. It passed the compression test with flying colors so I replaced the spark plug wires, since that was the most logical thing that would have caused a weak spark in only the one cylinder.
I fired the generator up today and it ran much better, but here’s the problem. The carburetor I have has environmental issues and is no longer being made, nor are service parts available for it. What I’m looking for is the initial starting point adjustments for the main jet adjustment screw and the idle jet adjustment screw. As it was, before I took the carburetor apart, I screwed both adjustment screws all the ways in, counting the number of revolutions on each screw before taking it all apart. When I put the carburetor back together I set the screws to those same adjustments. The generator initially ran too rich but after turning the main jet screw back in I had it running better but still not to my standards. I’d like to know what the factory recommended initial starting point jet screw adjustments are. It’s an Onan #7NHMFA261060 generator equipped with a Nikki #146-0580 carburetor. If anyone has a shop manual that covers that carburetor it might have those initial adjustment settings.
BTW you’ll never guess, I think this is funny and ironic, the recommended EPA blessed carburetor, which costs $380 is #146-0666 (the devil made them do it! LOL).
Steve
  • Start at 1 turn out. Once it starts and warms up turn the main in very slowly with the engine under load until the it starts to die then back out 1/4 plus a tich which is a bit more than a hair. Holding the throttle against the stop screw, no load this time, do the same with the idle mix screw. When you release the throttle shaft, it will snap open and the engine should pick up cleanly.
