Handbasket
Aug 18, 2013Explorer
If that wall is as smooth as it looks, you might try the small 3M Command hooks. I've used a lot of them and never had one let go, tho' I've never used them around water. Then either stretch some elastic between them, or use the mini-bungees. If the later, you might need to shorten them. Just push one end thru the hook, tie a solid knot, and cut the excess off.
Jim, "Given a 50-50 chance, you can be wrong 90% of the time."
38,778 PostsLatest Activity: Jun 06, 2026
