darsben
Nov 29, 2015Explorer II
timmac wrote:
Jeez he just wanted a simple answer, 80 to 90 psi would be the range you will want to use in 19.5 tires, I run 85 in my fronts and 90 in back..
If a 110 lb max tire and a upper weight limit MH it would be severely under inflated. Giving info on tire inflation without knowing what tire the guy runs IS DANGEROUS.
The ONLY GOOD ANSWER is run at the max pressure on the tire UNLESS you weigh the rig and use the tire inflation guide for your tire.
38,769 PostsLatest Activity: Dec 31, 2017
