timmac
Dec 01, 2015Explorer
darsben wrote:timmac wrote:
Jeez he just wanted a simple answer, 80 to 90 psi would be the range you will want to use in 19.5 tires, I run 85 in my fronts and 90 in back..
If a 110 lb max tire and a upper weight limit MH it would be severely under inflated. Giving info on tire inflation without knowing what tire the guy runs IS DANGEROUS.
The ONLY GOOD ANSWER is run at the max pressure on the tire UNLESS you weigh the rig and use the tire inflation guide for your tire.
If you note he has a 34 foot motorhome with one slideout on a P-32 chassis, his weight is about the same as mine so he will only need 80 to 90 psi on 19.5 tires..
Most 19.5 tires x 6 tires has a gross carrying weight of 27,000 lbs.
38,769 PostsLatest Activity: Apr 04, 2026
