tropical36
Jan 02, 2018Explorer II
mlwinnig wrote:
Onan Emerald Series gasoline generator...
Supposed to run for 30 - 45 minutes a month under load...
Generator shuts off when tanks drops below 1/4 tank so generator can't run coach out of fuel...
Don't want to keep stale ethanol fuel in bus to exercise generator...
Not convinced fuel "stabilizers" work with ethanol and not easy to get to good fuel...
Thinking of adding a small auxiliary tank and bypass valve for the sole purpose of exercising genny. Looking for input. Does this make sense? Ideas on requirements / issues, etc..
Thanks!
I like having a full tank, gasoline or diesel and don't worry about it getting stale, especially with gasoline.
But, if you insist, then just get yourself a 6 gallon boat tank, with a length of hose attached for disconnecting the genset fuel line and attaching the temporary. May have to plug the main, while you're at it, but no biggie and have done it lotsa times when troubleshooting. Have even done so, with a gallon milk jug and all that's really needed for this.
38,782 PostsLatest Activity: Sep 10, 2026
