Sully2
Oct 16, 2014Explorer
mike brez wrote:Sully2 wrote:
Go to Bradd & Hall. Direct replacements in about any covering you can think of
That was my first pick then saw the price at shop4seats. Probably one of those you get what you pay for. They have a mixed review.
Hey Gary do you know how and were your seat belts are fastened for your couch. I just picked mine up a couple months ago and someone changed the couch and cut out the seat belts. I pulled the carpet back and on both sides of the couch and there are what looked like 5/8" or a little bigger rod cut off flush with the floor. These were about six inches off the back and side wall on both sides of couch. Not sure if that was to hold the couch down or for seat belts. Thanks Mike
I'll have to look where the seat belt at fastened down for my sofa. As far as the other "bolts" you speak of Im positive they are the hold down bolts for the sofa. They came up and went thru a section of the angle iron framework of the sofa that was also the foot of it.
EDIT: Mike...as far as I can tell the sofa seat belts are also bolted directly to the floor. I can see LG studs amd the metal ends of the seat belt themselves have LARGE flat washer and what appears to be ( maybe??) 3/8 nuts on the bolting each one to the floor of the coach! I think it was for BOTH purposes..1) seat belts and 2) hold the sofa down. Hope that helps some??
Sully
38,769 PostsLatest Activity: Mar 31, 2026
