tropical36
Jun 26, 2016Explorer II
rookie_rv wrote:
Rookie Rver :C here and I need some guidance. Are there any benefits to changing / upgrading my generator? My Class A is 1996, the generator only 159hrs. Yeap, only 159hrs! Would a newer generator be more efficient, run quieter, "more better" in any way? Doing an over haul from top to bottom, front to back, inside and out.......
You're not saying, which coach you have or which genset is installed and can sometimes produce a lot of variables.
For instance, with some National products like mine, there is no same size replacement that will nicely fit where the 5.5 Generac model, is installed now.
Even, so and like one other member said, if it ain't broke, don't fix it and at the same time, I've fixed mine more than once, with finding that route, the best option.
