Heliarc
Aug 02, 2013Explorer
barnaclebill wrote:
W-300 was a 1 ton 4X4 pick-up or cab chassis...
Now I'm getting even more confused. The 1966 W-300 I had was equipped with the 318 "semi hemi" but it was a 2WD. Maybe someone switched the tags or swapped the front end for something else?
I'm hearing from other sources that I'll be looking for a DANA 60 or 70. Best bet might be a fire truck of all things. And of course the hardest part is going to be matching the ratios. I might have to look for a matched pair and throw in my present ten bolt rear as a bargaining chip. This might be turning into a real can of worms.
For now I'll just get the aux transmission mounted with a bearing on the input shaft, get it rolling, and put on some tire chains. I'll keep looking though and if the fates decide I need it I'll find it.
38,778 PostsLatest Activity: Jun 10, 2026
