barnaclebill
Aug 04, 2013Explorer
MrWizard wrote:So, I now have a running chassis of a 1978 Dodge Champion 25' motorhome. I believe it to be a class A since it's a cabover and the chassis is a much heavier build than a typical pickup truck. The title lists the GWVR as 12,500.Here, I found this......
1966 The lightest entry in the standard-sized trucks was the D-100. The half-ton and three-quarter-ton models had a new 128 inch wheelbase model for better weight distribution, and a choice of Sweptline or Utiline bodies; for 1966,
you have a 1978 NOT 1966
no mfg sat on a chassis for 12 yrs before building an RV
you could have a 78 RV built on a 77 chassis, this is every common, motorized RV's are titled by yr of completion/model not yr of chassis
most likely is you have an M-300 or M-400
it depends on the wheel base of the chassis
Mr Wizard, you did not read all the posts from the O/P. He had discussed his "1966 W-300 as being 2wheel drive"
38,778 PostsLatest Activity: Jun 10, 2026
