RobertRyan
Dec 29, 2014Explorer
pnichols wrote:
Those Host units on the Fuso 4X4 chassis sure look a little low on grey water capacity and LP capacity. However, fresh water capacity is great. I wonder where all that fresh water is going to wind up, considering that they're using a cassette toilet?
Their top speed (FWIW as a guage, only) versus their rated GVWR is indicative of what you give up with that little tiny diesel in them. Wow .... only 161 HP to move along a GCWR of 21,765 lbs.. Of course, the turbo will keep it pulling the best it's going to even in the High Sierras. Those very low ranges of available differential ratios (5.285:1 or 5.714:1) are probably what's absolutely required to get that little motor to do what it does - albeit slowly.
Yes a tiny 3 litre diesel, but as reliable with that drive train as Old Yella in Yosemite NP. Used to have a 4.9 but pollution regs killed that. These light trucks are used as very basic delivery vehicles here. Most countries outside the U.S. use Cassettes. Have not heard of problems with Grey Water or LP(Liquid Propane?)
IVECO Daily towing 38ft Redwood 5ver
Interestingly they use the IVECO Daily with a similar small 3 litre diesel to haul 38ft 5vers. To make up for the drop off in speed climbing long inclines a lot use LPG injected into the diesel to get better mileage and a similar speed up hills to a U.S. 6-6.7 Diesel
