kdk
Feb 15, 2016Explorer
Do some close measuring. Before you purchase look at a counter depth model ref. as the box on my 23.5 cu.ft. Samsung is 24" with the doors off verses 31" on a standard refer. My entrance door is 26" leaving 2" to spare allowing it to come through after removing the drivers and passenger seats. The old 1200 lrim also went out the door after removing it's doors. I have no vested interest in Samsung but they will not void your warranty when installed in a RV as some other manufacturers do. They will also run with no ill effects on a modified sine wave inverter as the incoming power is rectified to a DC voltage and the compressor and cooling fans all run on DC. These components also are variable speed and operate more efficiently using less power. My refer is above the furnace and by building a steel platform bolted through the floor and lowering it we still can reach the top shelf. Also removed the old wall that was adjacent to the Norcold. Yes it was a fairly large project but as Dennis says "I have to micro wave the ice cream to make it soft enough to serve". Had $1100 in the swap and never looked back. PM me if you have any questions or would like some pics. Blessings; Keith
