Ocean_Mist
Jun 26, 2017Explorer
New 06' Executive Owners... Ride Home
Spent about 1 hour looking over the coach and proceeded with the purchase.  Drove home over 2 days, and although had a few issues, it was a great, safe and memorable ride.  What a Coach...!
The seller was gracious and we had a fun time learning about our new coach.
Aqua-hot is low on is it Boiler fluid? and I forgot to ask how it works.
The Seller was not very handy and usually pays for everything to be done, which is fine. I am more detailed, and now the fun starts...
I did here some metallic noise going over bumps at low speed. I think it may be the rubber bushings and the rubber in between shock absorber where they attach to the frame...?
It does porpoise a bit on dips at high speed.
When i raise the TAG, It does not lift off the ground is that normal?
The steering seems loose, and requires a lot of correction. And, when an 18 wheeler passes me on the left, my Rig pushes to the right and I have to correct to the left but the steering is loos and so i have to correct again because it goes to far left. It doesn't feel like it's accurate. It's like loose. I understand it's an RV, but what are normal steering issues that i can repair/replace to make steering and chassis like new again?
I notice that while steering, it is hard to keep her centered as she wanders left then i have to correct right. This is constantly, and requires to much attention to drive. What items can I have Source engineering do to correct these issues? I mean i see that Source has 8 Airbag Ride Enhancement kit, I wonder if they have a 10 airbag Kit...?
When i use the remote to lock the bays, i hear them click, but only a few lock...
The seller neglected to tell me that the tile behind the chair was cracked. I can only imagine it was when someone activated slide without checking if passenger chair was too close. There is tape covering the area, which i did not see until my road trip.
I would like to address these issues and more. Below are some ideas I'd like to do. Can you take a look and offer suggestions...?
1. I Will see if I can pressure wash the entire underside of coach to see about any leaks.
2. Gently spray greaser on engine and generator and rinse with hose. No Pressure water there...
3. Contact Source Engineering for replacing all shocks and ask about Ride enhancement Kit. anyone use Source?
4. Anyone upgrade their bushings?
5. I can feel the bedroom is hot when we stop. Anyone have a link to those fans that remove engine heat?
6. Any other things Inherent or I should be aware of?
