Mr_Mark1
Jun 26, 2017Explorer
Ocean,
I would get a three axle alignment done first before adding additional parts. I think the steering 'correction' problem could be related to the alignment. I'm not a mechanic but I've seen this talked about many times on this site.
You might need to have the Aqua Hot serviced and checked out. The unit might need to be blown out and the nozzle replaced along with the fuel filter, etc.
If you 'wet' the engine area, try your best not to get the alternators wet.
I don't think fans in the engine area will make one bit of difference to remove heat. You've got a big-honking 600hp engine that puts out a lot of heat. You could maybe open the engine door when you park to dissipate the heat faster. I think the hot bedroom is normal. You can inspect the insulation in the engine area to see if it's there but we had the same issue with our Dynasty which I didn't see as a problem.
Our tag axle on the Dynasty would come all the way off of the ground. Make sure you are on level ground when you test it. It could be that it might need adjustment.
You can also check the dates on the airbags as they can age out.
The bay door locks might need to be sprayed with WD40. If your locks were like our Dynasty, you can take off the cover that is inside bay door and see how they operate.
Good luck,
MM.
Good luck,
MM.
