Mr_Mark1
Jun 26, 2017Explorer
joraz wrote:Aqua-hot is low on is it Boiler fluid? and I forgot to ask how it works.
We had Aqua Hot on one or our rigs. It just used standard anti-freeze coolant.
jor
Our Aqua Hot used 'Boiler Fluid' that was red in color.
Ocean, make sure and use the correct fluid as yours may use anti-freeze like joraz's.
Your Aqua Hot may very well have two electric elements that you can use to heat the water. The Aqua Hot (electric elements) can also be used to heat the coach if it's not too cold outside, maybe down to the low 40's, otherwise, you will have to kick on the diesel burner.
If the exhaust is really smoky/smelly, you probably need to have it serviced. The Aqua Hot will have a little exhaust smell but shouldn't smoke while running, it will probably have a little puff of smoke on start-up.
MM.
