Executive45
Jun 28, 2017Explorer III
OceanMist:
1. Your undercarriage should be sealed. No steam cleaning necessary.
2. Recommended service interval for the AquaHot is annually. I would have it serviced completely then either annually or every other year depending on how much you use it. The diesel boiler should be fired up at least once a month according to my mechanic. Make sure they check the fuel pressure gauge when doing the service. Cost is around $200.
3. My AquaHot uses special fluid. DO NOT MIX DIFFERENT FLUIDS. Determine what YOURS uses before adding anything.
4. You have a gauge in the engine compartment to adjust the tag. The lighter the tag, the lighter the front axle. Conversely, the heavier the tag, the heavier the front axle. Use that gauge to adjust any weight issues. Mine lifts off the ground but will automatically drop if you exceed 5MPH. Use caution if you are going over speed humps with the tag lifted. If it bumps the hump you may get an ABS warning signal that will persist until you exceed 35MPH and it resets.
5. A good alignment shop will make your steering issues disappear. I doubt you need to do anything else.
6. Once loaded for travel, get it weighed and adjust your tire pressure to specs.
7. Check the tire date codes.
8. Check the SCA in your radiator....Dennis
