Ivylog
Jun 28, 2017Explorer III
Sam, without the engine running you want less than 1/2" free play in the steering wheel...it costs nothing to adjust as the bolt with the lock nut is easy to get to on the side of the box. Start with a quarter turn CW...it has a slot in its head.
Chris, the OP has a heavier engine/tranny than you so your tag only needs 35 psi max. Are you having to hold pressure to the right to go straight or is the steering wheel not centered? If not centered it can be repositioned without doing an alignment.
