Ocean_Mist
Jul 03, 2017Explorer
Executive wrote:
OceanMist:
1. Your undercarriage should be sealed. No steam cleaning necessary.
2. Recommended service interval for the AquaHot is annually. I would have it serviced completely then either annually or every other year depending on how much you use it. The diesel boiler should be fired up at least once a month according to my mechanic. Make sure they check the fuel pressure gauge when doing the service. Cost is around $200.
3. My AquaHot uses special fluid. DO NOT MIX DIFFERENT FLUIDS. Determine what YOURS uses before adding anything.
4. You have a gauge in the engine compartment to adjust the tag. The lighter the tag, the lighter the front axle. Conversely, the heavier the tag, the heavier the front axle. Use that gauge to adjust any weight issues. Mine lifts off the ground but will automatically drop if you exceed 5MPH. Use caution if you are going over speed humps with the tag lifted. If it bumps the hump you may get an ABS warning signal that will persist until you exceed 35MPH and it resets.
5. A good alignment shop will make your steering issues disappear. I doubt you need to do anything else.
6. Once loaded for travel, get it weighed and adjust your tire pressure to specs.
7. Check the tire date codes.
8. Check the SCA in your radiator....Dennis
Ok, have the Aqua hot serviced annually. Is that something I can do or where is a good place to take it? Cworld?
That's good to hear about the Undercarriage. I will just clean the oil that has accumulated on the generator.
I will check to see which fluid my aquahot uses FIrST!...
Thank you about the 35mpg reset for the Tag. I could see myself combing the books for hours on that one...lol
Yes, that is great that I only need the current components to make the thing drive like a dream
Just curious, how one determines the air pressure to weight ratio...I think i also asked Ivy above?
I will check the date codes on tires...
And what is the SCA on the Radiator?
