Ocean_Mist
Jul 15, 2017Explorer
Ok guys, I have heard that Monaco Battery wires may have some issues with the elements maybe corroding the terminals.
I have cleaned all wires tips with a Wire wheel, however there are a buch of wires in between the Battery boxes that are connected to the 2 Main shut off switches.
It is almost inaccessible and the battery boxes are only about 4" apart.
In order to make sure all connections are good at all terminals, where wires come together, I need to get in there.
Is it advisable to cut into battery boxes sheet metal to get at those wires that are attached to the 2 main shut off 1/4 turn switches?
some of the ones I have removed have corrosion and I would like to hit them all to remove corrosion
It seems taht the battery boxes are almost sealed to the elements but there are holes that allow air. So i guess if i cut into the boxes, I should install a bracket, or hinge to re close said boxes
I don't know how did you guys handle that?
