Ivylog
Jul 15, 2017Explorer III
BS Alert:" He said it makes the rig handle better due to the faster recovery, and faster and more volume of air".
You can increase the air system pressure up to 125-8 psi... coke can size air governor near the air compressor. Take the black rubber cap off, loosen the locking nut and turn the adjusting screw CW probably one turn.
Take the knob off the cutoff switch and then the nut that holds the switch in...should have enough slack once you remove the switch to get to the connections without cutting anything.
