wildmanbaker
Oct 11, 2016Explorer
As you probably already know, if you can hear the solenoid clicking in, its either brushes, a flat spot on the armature, or a bad connection at the solenoid, or inside the starter. If you have a starter/alternator shop near you, they can more than likely fix the problem.
Good luck
Good luck
38,766 PostsLatest Activity: Jan 10, 2026
