Larrysr1957's avatar
Larrysr1957
New air conditioner problem
I just had 2 new a/c's installed on my 1997 Fleetwood Bounder (15000 in the front and 13,500 in the rear. Its a 30 amp supply motor home. The air conditioner cuts off and wont come back on for hours we are only running 1 of them. Are there any suggestions as to what the problem might be
I am thankful for all your help
  • ford truck guy wrote:
    Didn’t think 30amp would run 2 AC’s? I guess it wont, sure sounds like low voltage to me as well
    OP stated he is only using 1
  • Didn’t think 30amp would run 2 AC’s? I guess it wont, sure sounds like low voltage to me as well
  • are you on shore power or generator? sound like low voltage and the unit is cutting out on thermal
    low voltage = high amps which creates high heat,the thermal kick off till it cools down.
