MrWizard
Feb 18, 2020Moderator
Make/model number of inverter
Would be helpful
In my Bounder, The location you describe came with a converter aka battery charger not an inverter
I installed a stand alone inverter in that compartment
The factory wire from converter to the batteries up front is only 8ga, adequate for the house 12v loads and battery charging from the 40 amp charger but not too power an inverter ... To much voltage drop
It sounds like you are describing the standard converter
That charges the batteries and supplies DC power for the RV house systems when 120vac is available
Not an inverter that makes 120 vac using the batteries
Would be helpful
38,782 PostsLatest Activity: Sep 02, 2026
