cavie
Feb 19, 2020Explorer
CodyWest wrote:
OK I got it. Thanks even the non-reader from Mobay (probably Prunedale or Marina). It will be replaced. I thought it was an inverter. It obviously is not working. I'm learning quickly about Fleetwood quality
Tell use how you know it is not working?? If it is an inverter it will have large 12 volt wires feeding it from then battery and a 120 volt output side. If it is the converter it will have 120 input wires and 12 volt output wires to charge the batteries. You need a volt meter. You need to learn what you are looking at.
You are not learning about Fleetwood Quality. You are learning about RV quality across all manufacturers.
38,782 PostsLatest Activity: Sep 02, 2026
