powderman426
Nov 14, 2014Explorer
DSDP Don wrote:
"wildtoad"......the boxes are a cheap fix by the campground.....it's not the cable companies fault. They can easily send a digital signal. In this day and age, there are numerous systems that can be installed to provide cable or OTA TV without a box.
Could you give an example of these numerous systems that will deal with a digitally encrypted signal???
BTW the park where I winter gives a box with each site and their way of assuring they get it back is to make you provide a credit card. If you want to keep the box, they just cridit your account. As for the need to run wires through the window, It shouldn't be necessary. You just hook up like you normally do and connect the box between the incoming line and the TV. If you have more than one TV, it is required that you go and get one from the cable provider. They don't charge for the box, but like the park they make you provide a cc. Not an ideal situation if just staying a night or two, but not bad if staying a couple months or more. The upside is that ppv is now available.
38,766 PostsLatest Activity: Jan 10, 2026
