msturtz
Jan 30, 2018Explorer
bclinton wrote:msturtz wrote:bclinton wrote:
So, after research I will be unable to install a permanent cover due to local codes. Here they have to be 5 feet from the property line and 10 feet from my house.....so....for the folks that are using a tarp where did you get it from? I am thinking covering the roof and maybe a foot or down on the sides would be better than nothing and easier to put on and take off.
Please do not use a tarp. It will damage the paint, roof, equipment on the roof such as air conditioners, antennas, plumbing vents and ladder. They are actually worse than nothing. It holds in moisture because it doesn't breathe when the water underneath evaporates. The commercial RV covers are made of a fabric that is waterproof on the outside but when water turns into water vapor it can escape. This keeps the rig from staying wet.
Do they make a half cover. I might be wrong but is seems that putting one on that basically covers the roof and maybe a foot or 2 would be much easier to deal with.....
I have never heard of a partial cover. It would be very difficult to make a cover for part of the RV. The first reason is not damaging the paint. Covers come all the way to the bottom of the coach so the stress is not on a painted surface. Next if you partially cover the rig you will have differential UV fading problems with the paint. Really if you maintain your roof it will be fine. The only other option I can think of is a “temporary “ shelter. They are usually made of some sort of tarp material and have poles that hold them up. Typically the don’t cost much and because they are not “permanent “ are not subject to permitting. Most of the time they are held down by large concrete blocks.
38,777 PostsLatest Activity: Jun 28, 2025
