jaycocamper6230
Feb 13, 2019Explorer
way2roll wrote:fred42 wrote:
This may be useful:
https://library.rvusa.com/brochure/2006_challenger.pdf
Based on the specs for the 353, the weight (if this is the F53) from factory is 17,164, and GCWR is 26,000. That's a net of almost 9,000 lbs. IF the weight is accurate (and they aren't always) there would be plenty of capacity. Add fuel, food, water, people etc, and you would still be well within the max 5,000 lbs the hitch is rated for. If you add all the weight you would add (fuel, food, people, water, and the jeep) and it's under 9,000 lbs, you would be ok provided the jeep doesn't weigh more than the hitch rating of 5,000.
Yes it's a F53 chassis and thanks
