Desert_Captain
Sep 21, 2015Explorer III
stew9483 wrote:
Just got back from my first trip in our NEW Thor Chateau 31E Motorhome and I must say there were a few white knuckle experiences. It was rather windy the first day. So I have went and purchased a Roadmaster Reflex steering stabilizer and a Hellwig rear sway bar hoping this will help out a lot. Have any of you tried these products on your Class C? They came highly recommended and I want to enjoy this RV not be scared to drive it. We bought it to head across country and to enjoy the camping life style again. We had a travel trailer back in the 90's and loved it. Now the kids are grown and its our time. Hope to get these installed next week before our next trip.
Your post illustrates the necessity for a thorough test drive Before buying any RV, new or used. Any rig, especially a new one, that needs thousands of dollars of of suspension modifications right off the dealers lot is the wrong product.
A simple check of the tire pressures before the test drive is essential. You can split the difference between the dry weight and the GVWR as a starting g point (for an empty coach) and set the psi accordingly based upon the tire manufacturers recommendations. Run from any dealer who balks at doing this.
A test drive should include some serious interstate time at a variety of speeds, hopefully on a windy day. How does it respond to passing 18 wheelers? How is the visibility (blind spots)? A run up and down a healthy grade, 6% would be ideal but probably not available). Does it track in a straight line without steering input? It should.
Often merely getting the tire pressures correct and perhaps a proper alignment (which most rigs do not come with), will negate any need to spend thousands of dollars on after market bolt on solutions {which may or may not work}.
As always.... opinions and YMMV.
:C
38,782 PostsLatest Activity: Aug 23, 2026
