ron_dittmer
Sep 24, 2015Explorer III
IAMICHABOD wrote:I read on this forum all the time how the handling issues are so much worse with the Ford compared to the Chevy/GM. I also read that the dimensions on the frame of the Ford are so much better than that of the Chevy. So why these handling differences?ntar827 wrote:
It appears that the comments are from owners of C's on a Ford chassis.
Are the problems also there with the Chevy?
Thanks
No, the Chevy based Class C does not have the same problems in stability that the Ford Based Class Cs have.
To learn more about Chevy Based Class Cs Just Click Here.
In camp grounds, when I see the front of a Ford raised on hydraulic levelers, the front wheels are literally tucked underneath at a significant inward (pigeon-toe) angle. Does the Chevy do the same? If not, maybe this is the matter at hand. When the Ford front hits a bump, leans, etc, you then need steering correction.
38,782 PostsLatest Activity: Sep 10, 2026
