holstein13
Dec 01, 2014Explorer II
draboo wrote:I think 10 gauge is probably too small. You want the least amount of loss possible. Yes, you could run the wires under your coach in some protective corrugated wire loom and then drill up into the battery compartment. But you are safer to find a path through the insides of the compartments.
I have plenty of 10 gauge wire to hook up directly to the batteries. But the batteries are on the other side of the motorhome. Can I attache the new wire on the underside till I get to the battery compartment, then drill a hole? Originally this is what I wanted to do,but I wasn't sure how to go aboot it.
