gemert
Mar 27, 2016Explorer
Congrats on your new coach! I am not an expert but I have never heard of a converter charger that was not supposed to charge your house batteries. That's what they do. I would plug the coach into a known good shore power and check across both of the 6 volt batteries. In other words, from the positive on one battery to the negative on the other battery. That should read initially at least 13.8 VDC or more. As the batteries become charged the voltage should go down to 12.5ish. If you don't get a charging voltage (12.8-14 VDC, some as high as 18 VDC)then the charger is not working or there is a broken or loose connection. Again, not an expert but thats how my RVs have operated. Good luck
PS. On edit...put your coach info in your signature or some of the old fuddy duddies on here will give you hell! Me I know so little about other people's coaches that I don't care! LOL
38,777 PostsLatest Activity: May 24, 2026
