DSDP_Don
Mar 27, 2016Explorer
"Vibrant93".....Your converter charger only has two jobs....convert 110 volts to 12 volt and charge your batteries. It sounds like you the ability to use a voltmeter, so pull it out. Locate the converter charger and identify the two large wires that go to the batteries. It should be pretty easy to identify those. Take your meter and check those two wires at the converter/charger. They should be showing the voltage "gemert" discussed above. If not, the charger side is not working. If it's not working, check the entire unit carefully. Some have one or two blade type fuses plugged into the body of the unit. Check your Magnetek manual or go on line and download it.....and look for any fuses.
If the unit is putting out the correct voltage, you'll need to follow those large wires to the house batteries and check everything along the way and see where the connection is broken or there is a hidden fuse.
38,777 PostsLatest Activity: May 24, 2026
