mowermech
Mar 28, 2016Explorer II
aCheck the output voltage at the converter output terminals when plugged in to shore power. then check the battery voltage. The VDC readings should be nearly identical. If not, there is something wrong between the converter and the batteries. Are you sure the master disconnect is ON, so the batteries are connected to the circuits?
