Vibrant93
Mar 28, 2016Explorer
tderonne wrote:
A quick check for the converter is to turn off the aux battery switch while plugged into shorepower. Coach 12 volt systems should remain on being powered by the converter. I suspect you'll be in the dark...
You are correct, I'm in the dark when I do that! I just assumed that the aux battery switch always had to be on, regardless of shore power being involved or not.... I'm learning here guys.
Thanks for all the help!
