Gjac
Mar 29, 2016Explorer III
Until you check the output of your converter as Mowermech suggested we are all just guessing. The Magnatec is a very simple converter and and should put out 13.2 - 13.8 VDC. If I had to guess I would suspect your cables from the converter to your batteries either corroded or loose, or a burned relay/solenoid in your battery disconnect. You should read 13 + VDC at your converter output when plugged in to shore power and at your batteries if everything is working correctly. A reading of 13+ v at your converter and just resting battery voltage at your batteries(12 v or so) would indicate what I suggested above. Find out your problem first before buying a new converter and finding your problem was just a loose cable. Good luck.
