tropical36
Mar 29, 2016Explorer II
Vibrant93 wrote:
Hey guys, 1st time poster here. Been a member since '02 (what's that tell you) but finally got life in order enough to settle down with a coach! The wife and I just picked up an '00 Itasca Suncruiser 35u. 1st thing we've done was grab a couple of 6 volt batteries and put them in series for the house side. Here is where I kick the dead horse... What I'm noticing is that they are doing the job very well but I feel as though they are not receiving a charge when plugged into shore power. AKA not seeing a voltage on the house side above 12.2 with the master disconnect on and 30 amp shore service. This coach has a Magnetek 7455 converter/charger of which I've located and checked fuses. Everything checks out with the fuses. My question... Even though the coach has this converter with a charger function, does that mean the coach is wired for the charge feature that the converter offers? After hours of reading various posts and trying to go through schematics I feel as though there isn't a definitive answer. I don't have a problem upgrading to a 3 phase converter if mine has a bad charge side but doing so and still not having the charging function work is going to be an issue. Thanks everyone for taking the time to read this but does anyone really know? Do the 2000 model Itasca Suncruiser 35u's take a charge off shore power if they were factory equipped with a Magnetek 7455 converter?
Hard to say what the problem might be without personally troubleshooting the thing and assuming that you do have a 120vac input. You might pull the cover with drilling out the rivets if needed and see if you have the proper DC output there.
Having said this, I never could fix my heavy outdated OEM model and replaced it with this one....Converter Charger
Knowing now, would have replaced it anyway, whether the old one was bad or not.
