Before changing out to the residential, which was less than $1300 BTW, I installed three computer type fans above the fridge which help a lot. It seems one of the biggest issues with the 1200s is that the two fans they put on those fail all too often. Since they are pretty quiet you don't realize they've failed and since you can't see them you don't know it until it's too late. I found the 1200 was a great fridge when it's working properly, but when the second one failed, I switched to residential. Biggest difference is 12 cu ft vs 20 cu ft in the same space....best of luck to you. Enjoy camping....Dennis
