jsw513
Jul 03, 2014Explorer
tpi wrote:
I think the 200 watts is fine. Thats what I have. I have 300 amp hours of battery capacity, but 225 should do (2 6 volts). If I'm in a mild climate I usually do not need to run generator at all on a trip. I think w/ 200 watts solar and conservation you will not need to run generator 1-3 hours per day.
I'll be in the desert with 100+F degree heat....I'll probably need to run the generator a little bit, right? I won't be able to power that off my batteries, correct?
38,769 PostsLatest Activity: Dec 31, 2014
