I know you didn’t ask about Rancho’s. But I will toss this out for your consideration anyway, since its fresh for me and I just went through it. I had pretty much decided to go Bilstein myself based off prices and I have had them a couple times in the past and liked them. Instead I replaced my shocks on my 2008 Ram ¾ ton with Rancho 9000 adjustable shocks. Each shock has a dial with 9 or 10 adjustments on them for ride comfort and application choice. I have them set on #3 for an empty truck and the ride is far better then what I had. I ordered them from RockAuto and they had a real good price on them. Then couple that with Rancho has a
$120 rebate on them if you order 4 of them. In the end the cost was about the same prices as Bilstein and gave some selection in ride quality. Also I had some question on the correct part numbers and a couple other things and Rancho tech support was fantastic. Not sure if they have them for your application and the rebate applies for you but it might be worth a third consideration. I added them and Timbrens to my suspension and I am very pleased so far, but I have only had them on a few months.
