FloridaNative49's avatar
Jan 13, 2018
New Shocks
Need new Shocks—2012 Winnebago Adventurer 37F
WHERE would you go to replace them?
Would you stay with Bilstein?
Not that old, and 35,000 mi.
Love the coach but slightest dip and it rocks all over. Have tried rebalancing load etc. but I think it’s time. Did add the Safe T Steer year ago or so — helped a little.
Thnx.
  • Based on our experience with a 2014 F53 from when it was new, I'm unimpressed with the Bilsteins in this application. The Koni get good reviews.
    If there's not a local shop you like, buy shocks online and have a mobile mechanic come to your place. I would be changing my own.
  • My 2001 Ford F-53: Got new tires around 30,000....Camping World, by coincidence, had the best prices going...plus a large rebate from the mfgr. Save $70/tire, compared to other tire places. While there, I asked them to check the shocks...long story short, the Ford products (original) were nothing more than rubber bands. I had CW put on Bilsteins. Still have them years later and they seem to do the job.
  • Koni FSDs are quite good (but not inexpensive) and are what I put on my (class C) motorhome. The variable frequency valving seems to work very nicely indeed, not being too stiff on little bumps or vibrations while controlling big ones decently.
    When I replaced them, I ordered the new ones from shockwarehouse.com (no affiliation other than a customer) and went to my driveway to put them in. Changing them should be pretty straightforward. On the E series, the fronts are trickier because there is not much clearance above the top mount to manipulate the mounting nuts, but I suspect that's likely to be less of an issue on most class A's. If you aren't up for doing the work yourself, most any halfway competent shop should be able to handle it.
    Assuming this is rocking side to side, improving the anti sway bar setup would help a lot as well.
