FormerBoater wrote:
How do you know 85 PSI is the correct cold inflation pressure for your load?
Based upon your post, it sounds like it may not be.
Very rare for the same tire pressure to be correct for all six or eight tires on a Class A.
FormerBoater: Thanks for your reply. And, yes, I do not know that 85 is correct and yes I do know that having each corner weighed and then inflated according the manufacturer's chart is necessary (I did that on my previous MH). I haven't done so yet with this MH but have only made a couple of fairly short trips. I do, however, intend to have it weighed before my next trip. After having it weighed, let's assume that weight on one of the wheels requires that tire to be inflated to...say 90 psi. I inflate to that pressure and then when I start driving on these hot Florida roads won't the pressure still increase 10 to 15 pounds over the required pressure as is occuring now and again resulting in harsh ride and steering difficulties? I believe I know the answer to that question and that it is that there is likely no preventing pressure increase due to road heat. Am I correct? Again, thanks for your reply. / Larry
