The tire manufacturers factor in the expected pressure change when determining the cold inflation pressure. The listed pressure is the minimum required to support that load.
The figures quoted for the relation between speed and weight capacity are very optimistic. In the Michelin Tire Manual, (Page 10) the chart shows that at 11-20 mph there is a 17% increase in load capacity if tire pressure is increased by 15psi over the maximum. An 8000 pound rated tire could carry 9360 pounds.
Michelin Truck Tire ManualThis procedure of carrying additional weight above rated load is for heavy truck and bus tires, it is not mentioned as a viable option for RV tires.
