MrWizard
Jun 30, 2017Moderator
This is a guess, only a guess
That tire has a weak spot in the side wall
When you park on that spot on the pavement
It leaks air at the bead, after it leaks down enough, it just collapses and breaks bead
As a test Mark that spot with chalk for paint, air the tire and don't park on that spot
If it does not leak after several times of doing this
Park it on that spot, spot down, and see if it goes flat again
You have to make Mark the tire and the wheel before you get it repaired aka aired back up
Once it is aired up and appears to be holding
Do not check the pressure, do not touch the valve
You want to eliminate that from the test,
If it does not go flat when parked on the spot , replace the valve
Heck pay a few bucks and have it replaced now while getting the tire aired back up
