Hank85713
Nov 14, 2014Explorer
The Melborne should have the camera already built in as it is a B+ and one of their top line models. We almost bought one as it hass the best driver area with the electric seats and all the remote adjustable mirrors etc. Your camera should also work while towing so you can monitor whatever is behind you while traveling along. I think you can add the side cameras to the system not sure, but after a while they are really not needed. Just practice driving. As to tail swing go to like a school bus bay which has the warning line fot the kids. park as close to the curb as you can. from a dead stop turn the wheel all the way to the left without forward movement. Watch the r/s mirror as the tail swings over the curb to give you an idea of tail swing. Can even do this at a mall with islands but the school curb is the best. You will lose the effect if you allow any forward movement as it diminishes the amount of tail swing. For right side turn do it in a mall lot next to the median if possible.
As to height I believe it is less than 13 ft tall at the top of AC unit. Easy to measure if in doubt. Yes be careful on driveways as desert capt said. Make sure your air bags are set I run mine at 50psi and it makes a difference.
38,766 PostsLatest Activity: Jan 10, 2026
