Here are a couple more thoughts. Our previous RV was a 5er and I assume a TT is similar in that we had ample kitchen counter space. With a C, not so much. As mentioned above, you will find the rear end dragging on the ground when going in and out of some driveways or gas stations. Suggest you instal a roller or two at the rear of the rig. One other item which is important. Be aware of the tail swing of MHs. As you turn sharply left or right, the tail of the rig will swing outward. Leaving a gas station once, I parked somewhat close to the gas pump. When leaving, I had to turn right to exit. The next thing I new is my rear driver's side hit a cement post by the pumps and damaged that part of my couch.
