mikebo
Jul 18, 2013Explorer
The one big difference that you may be aware of is you don't want to ever try to back up when towing a toad. Also you should always try to be moving before you start to turn so that the toad wheels are moving before they are pulled sideways.
Your 32 ft class c probably has a wheelbase of 215 to 220 inches, much longer than your jeep, thus you will be making much wider turns. I have found the biggest issue is getting started backing into campsites that are perpendicular to the road. Many campground roads are too narrow to just back in, generally takes a few back and forths to get the motorhome turned without leaving the paved surface.
38,768 PostsLatest Activity: Nov 21, 2015
