bproulx12
Oct 16, 2014Explorer
Was just looking at the GoPower transfer switch, I hope these transfer switches are meant to be separate from the one that cam ewith the RV. But the diagram installation on the Gopower pre-wired transfer switch has it going to the AC Panel and/or to the 30 amp shore power (confused) it would be nice to have something that would do it automatically. Would it be not easier just to put a switch on the charge/converter and turn it off then turn on the inverter? or plug it into a on off switch of some type instead of a pin the B+ cable, of course a breaker would do the same thing, but I would have to put it in a panel and that may be complicated.. then just plug the 30 amp shore cable to the inverter.Well I have the renogy MPPT Charge Controller, of course this was before reading that MPPT is pretty much worthless unless you have a 1000 Watt Solar setup. Mine is only 400. I chose the IOTA DLS-55 for the charge controller. with the smart IQ4.
38,769 PostsLatest Activity: Mar 31, 2026
