blazenpm
Jul 28, 2015Explorer
very important to have the transmission serviced. Whatever is needed. If it needs to be purged, then do it. I run a synthetic autotrans fluid in mine. The synthetic fluid holds its viscosity better and is not affected by the heat as much as non synthetic autotrans fluid. How are your tires? Make sure they are all in good shape especially the inside duals that you cannot see. They say tires should be changed out after they get seven years old, I think if they do not have any cracks and have good tread and still hold air then run them, but most RV'rs feel that the tires are they one of the most important things on a motorhome to have in best condition. How is your generator working? I had mine serviced as it would not start. The don't mess around with the carburator, just replace it with a new one. Had the plugs replace and filters gas and oil and oil changed. It runs great now. Oh, a friend of mine who is certified in Onan generators says those carbs can very easily be cleaned up with a carb kit and it would work like new. I found that out after the fact.
38,780 PostsLatest Activity: Mar 30, 2014
