MrWizard
Mar 07, 2018Moderator
The Lp tank is outside, the hatch/access door is marked
It must be turned on for the fridge to light
Very likely you have a 'tell tale' , propane control detector, it must be turned on before LP appliances will work, the little green light will blink when working, you will find it at floor level, it must be turned on, takes a minute to come on and open the lp safety shut off
You need the RV level to operate the fridge with out damaging it....When parked!
You need good batteries on the house side
Everything fridge controls, water heater ignition, furnace heat control etc.. work from 12vdc battery power, also the lights and the water pump
38,763 PostsLatest Activity: Dec 05, 2025
