fyrflie
Jul 13, 2019Explorer III
Pressures listed in RV are maximum pressures.
The only way to know the correct pressure is to weigh the RV then use Michelin’s inflation table to determine correct pressure.
When you weigh the RV, you need the front axle weight and the rear axle weight. Then calculate pressures accordingly.
With my RV, it worked out that all my pressures on all tires are the same which makes it easy to remember, but your results may be different.
