Bill_Satellite
Jul 13, 2019Explorer II
The above post is correct other than you should actually try to get each wheel weighed for an accurate determination of tire pressure. If you are just weighing front and rear you can use the Michelin pressure guide but you should add 5# to try to accommodate one side being somewhat heavier than the other. No one on the forum can tell you the correct pressure. No one. You must know the RV weights before making any adjustments. Never exceed the pressure listed on the tire sidewalls and be sure your tires are cold when you set the pressure.
